Beelink CS-George Minki Hi there , Your PC brand is 零刻,not beelink ,and your PC is a barebone, you need to buy the KEY by yourself.
Minki What is different between 零刻 and beelink? I know the two are the same brand. When I bought it last March, I got Windows code from here. But Windows asked me a valide code, when I turned on PC after several months.
Beelink CS-George Minki They are the same Company,but not the same brand. Your PC is a barebone, it comes without the key, so you need to buy the key
