Makis Hi! I didn’t find these cards in the compatibility lists. They will be added later or are compatible like the 3060-TI they replaced? Thank you!
support16 Makis Hi there,do you mean the EX Pro docking station.It supports with RTX 4060-TI or 5060-TI. You could take a look at our official website:https://www.bee-link.com/cdn/shop/files/EX_-1__19_large.jpg?v=1752343267
