Hello!
I recently added a second PC to my setup. I have a U59 Mini PC for personal use and another PC for professional use. I added a docking station so I wouldn’t have to switch peripherals every time I wanted to use the other machine. When I plug the docking station into the USB-C of the professional machine, everything works great. On the U59, however, Windows 11 recognizes both external displays (I see 1 and 2 in Display Settings), but it can only ever use one display. I can switch back and forth between 1 and 2, but Extend These Displays does not work. I have updated my display drivers. When I boot up the U59, I see the Beelink splash screen on both monitors, but Windows only shows on one. If I unplug the HDMI cables from the docking station, and plug them in manually into the U59, everything works fine.
Could there be something wrong with the U59’s USB-C port such that it can’t support the “bandwidth” needed for two displays and my other peripherals?
