How to change Windows version to English interface.
Please reset the PC.
Reset
Do this twice
Please try each option one at a time, then see if Windows will boot . . .
Then start the Reset
I can not find a default SSD brand of Ser8 in manual.
Can you tell me what brand?
So I can get a new SSD (same type, same brand for best performance) to run Raid.
Our SSD could be crucial kingston or other brands etc . you can find the SSD specs as above.
How to find a activation code of Windows,
Drivers and how to install for best?
I need to reinstall Window for setup Raid (as tutorial).
SYSTEM FILE
https://mega.nz/file/rmJ3yZaD#DaGj2QvxYIxs1AncTPZDoNn3grSjc4ELv-Hidx8RNp8
This is tutorial of how to install it .
https://url.bee-link.cn/s88O
Drivers
https://mega.nz/file/uqIjVKLQ#qdCLj6Z3V-uZ_HnPIAMlCBK2sQjB0OoCFjf8IjOgtuM
