DaYngSta Can someone please tell me the default bios configuration for the ME Mini. After updating BIOS to M1V305 i was having problems with machine freezing and so i changed some bios settings. Now it’s worst, it’s freezing and cpu is always pinned to 100% and getting blue screen. I didn’t note the original settings and need help. Thank you, .
support1 DaYngSta Please repeatedly press delete key as soon as you turn on the PC, go to BIOS. On Save&Exit page, please click Restore defaults, press enter to confirm, then press F4 to save.
DaYngSta I know that default but does that bring it to the state when it was shipped to me, Even before the bios update. I just want to make sure i’m starting fresh with good configuration. Ofcourse it’s not going to put the original bios back but im just looking to get good configuration back. Thank you,
support1 Hi there, please downgrade it to V303 to see if the PC works fine . Please check the file in your private message
DaYngSta OK, I will check the file. see the attached image after resetting to default bios. ( I will try the downgrade in a little while and let you know). See the attached image and it will show the constant 100% spike to the CPU
