Where do I find the activation for Win 11 Pro on a GTI14? There is no sticker on the back like others have shown.
Also the support website is not functional. Where do I find all the GTI drivers needed to update WIN11?
Thank you,
John
    3 months later
    These drivers do not help as the standard Windows 11 install does not accept them.
    At the stage my band new Beelink GTi14 is bricked and I have no option to return it.
    At this stage my band new Beelink GTi14 is bricked and I have no option to return it.
    At the stage my band new Beelink GTi14 is bricked and I have no other option but to return it.
      11 days later
      All good now.
      I’m not expecting a Mac Mini level of user experience but gee you are expecting a lot of users to undertake driver / bios updates.
        Marbles Hi there,
        If your PC doesn’t have any problem , you don’t have to update the driver or BIOS.
        a month later
        The newest Windows 11 Pro image let’s you skip the Wifi/LAN requirement.
        @[deleted]
        If this is how my Device Manager looks which drivers am I then missing?
        Image description
        @[deleted]
        Image description
        @[deleted]
        If this is how my Device manager looks which drivers am I then missing?
        Image description
        @[deleted]
        I have installed the following drivers from the driver zip:
        1. Chipset
        2. Intel CSME
        3. SerialIO
        4. Wireless
        5. Bluetooth
        6. LAN
          ETU813
          SD
          [unknown]
          [unknown]
        Hadn’t realized I could simply click on the device with missing drivers and point to the drivers folder and then it would sort it all out.
          Dear Support,
          I proceeded with Windows 11 reinstallation today and I have a blocking issue with Network Drivers
          I know you are on holliday, but I hope you can help me with this before february the 5th because I am completely stuck
          I did exactly as instructed in your tutorial, Win 11 installation went fine
          But I have no network at all, it wont install the drivers
          Here is my Device Manager:
          Image description
          The following devices have no driver:
          • Network Controller
          • The 2 Ethernet Adapters
            … and one Unknow Device
          I did as instructed, right click on each device -> Install Driver -> Browse to my Drivers Folder
          And here is the answer I get
          (Windows could not install your Network Controller, Windows could not find a driver for your machine)
          Image description
          Here is the driver Pack I am using. I downloaded it from a link on the forum when I was waiting for my PC to ship…
          Image description
          I thought, maybe this driver pack is too old (2024.07.09)
          If that’s the case, could you please provide the link to the correct Drivers Pack for GTI14 Ultra ?
          Or maybe there is another issue ?
          Please Help ??
          Wishing you a very happy Chinese New Year of the Snake ????
          Kind regards
