HI there .
I am sorry for the problem.
1.Please make sure your WIFI signal is full.
- Make sure that the distance between the PC and the router is less than 6 meters.
- Please uninstall the wifi and bluetooth drivers and then restart the PC to see if it works.
- Please right click the windows —setting -troubleshooting —other troubleshooters— internet—run , let the PC diagnose the problem and solve it automatically.
5.Please update the driver. Here is the driver source :https://www.bee-link.com/cms/support/productlist?id=7, click the item model , then you can find the related driver.
- Go to device manager , click the property of the Intel WiFi driver —advanced–choose property 802 ax, value also choose 802 ax.
7.CLR CMOS
Secondly, Please hit the “CLR CMOS” button for about 10 seconds.
Ten minutes later, plug the power supply and HDMI cable, turn on the PC again,
8.Please right click the windows–computer management–double click Services–①Wlan auto config–start the service, ②WWAN Auto config —start the service.
9.Go to the windows terminal (admin) > type in : sfc /scannow > then wait until finished.
Here` s a software for you to fix the WIFI issue, see if it works.
Please try this software https://mega.nz/file/X7hGVZwb#1tA5wEJhxH8BDtKxeB5qS2ZiIEUByAVZoOnzhSf4-Pg
