This is not acceptable, it’s false advertisement which is illegal in germany!
I bought the Ser5 Max 6800h because of it’s gaming power. Limiting the chip to 28W means I can not use the power you are advertising. The Chip needs 45W, PERIOD. With 28W it can’t even handle WOW on lowest settings, ridiculous!
I will wait 3 days, if the Beelink team continues to ignore the problem I will send the product back and inform Amazon about this clearly false advertisement.
