Hi,
I have a U59 Mini PC. I have attached my Mini PC Serial No and BIOS Page. 8 GB DDR4 256 GB SSD.
The Mini PC is Super Excellent. Had no issues with this. Last week it shut down 2 times due to power failure. After a bit of 2-3 minutes delay it re-started and doing fine. After this incident, though it is working fine like earlier, I am finding it a bit slow during initial start-up. It takes about 1-2 minutes to get the Windows 11 Login Screen. Earlier, the Windows 11 Login Screen used to come within 20-30 seconds. Once it starts, there is absolutely no problem, working like before.
I checked the BIOS and loaded the defaults. However, the slow starting continues. Just wish to know whether any settings got changed or is there any BIOS update which I need to make. If any specific setting is available in BIOS, Please let me know.
Thanks & Regards,
Kamalakar
