你好!
My Mini S12 Pro BIOS is:
Version: ADLNV104
Release Date: 04/19/2023
BIOS Revision: 5.26
May I know if I need to update the firmware?
I also want to review the change-log so that I can decide whether to upgrade or stick to the current version?
Thanks in advance! 谢谢!
The latest version is V106, which solve the password problem in the BIOS.
Would you like to update it ?
May I know what’s the password problem in the BIOS? Do you have a detailed article somewhere that I can read to decide if I want it fixed?
And if I want to update, how do I do it? I’m running Ubuntu on the MiniPC. Can I do it from within Ubuntu? Thanks!
