- #1
12th Gen Intel Alder Lake-N100 Processor (up to 3.40GHz) Wi-11 Pro Mini Computer
why don’t they send an email to reset password?
thanks in advance
thanks in advance
SaggiMC
Do you mean that your login password is lost ?
Do this twice
Then start the Reset
start up did’t have a problem it was just forgotten password, which I finally resolved afer hours on youtube and internet
boot up> on log in screen go bottom right, hold finger on shift key, press restart
this should open in advanced options, go to troubleshoot, reset, don’t press ‘keep files and programs’ go to one underneath, clean reset
when it reboots password has gone and you can input new one
