tranb3r Hi, Is it possible to upgrade the AX200 Wifi/BT card in a SER8, and replace it with AX210 or BE202 or BE202 ? Thanks
Beelink CS-Ian Chan tranb3r Hi there For BE200 or BE202 , It might not work with SER8 . Sorry about it .
Beelink CS-Rose tranb3r The SER8 uses Wi-Fi 6, while the BE200 or BE202 uses Wi-Fi 7, so it’s not applicable. We currently don’t have test data.
tranb3r It uses Wi-Fi 6 because it has the AX200 card. But when upgraded to AX210, it benefits from Wi-Fi 6e. So my question is, can I also upgrade to BE200 or BE202 to benefit from Wi-Fi 7 and BT 5.4 ?
Beelink CS-Ian Chan tranb3r Hi there SER8 only works for wifi6 /6e , It won`t be compatible for BE200 or BE202 /WIFI7 I am afraid.
