Hi,
I have bought several Beelink SER5 Pro Mini PC, AMD Ryzen 7 5800H and I have bought keyboard and mouse wireless MK270 of logitech. I have a lot of lag with the mouse. I would need a solution. I have read some tips about how to fix the problem but I couldn’t fix the problem.
In addition, I have test 4 different new mk270 and mk295 logitech keyboard/mouse. I bought 6 computers.
On the 6 computer I have the same latency.
thanks for your help.
For wireless devices . it might not be stable .
but you can use an USB external adaptor for wireless devices .
that would help peripherals run stable.
and it `s better to use wired devices.
So there is no solution ? some driver that fix the lag of the mouse?
The computer has bluetooth 5.2 it should work perfectly, I can’t understand how a new computer can’t manage a simple mouse correctly.
I will ask for a refund for the computers.
Thank you.
    missa
    HI There
    I am sorry.PC is more stable for wired device.
    But please try some solutions here if you may :
    ① Please go to the device manager to check if there is bluetooth driver, if no, please update the driver. Here is the driver source :https://dr.bee-link.cn/?dir= click the item model , then you can find the related driver.
    ② Please clear the CMOS. Please turn off the PC , unplug the power supply, and press the CMOS button (or poke the hole of CMOS with a pin) for about 10 seconds . Next, restart the PC after ten minutes. Here is the tutorial https://mega.nz/file/2nIRGaYI#M2aIM2bkOJshrhE8sK8MNiKopfyHlqyjnn86TypZp2w or https://url.bee-link.cn/5FdW
    ③Please right click the windows–computer management–double click Services–bluetooth–start the service.
    ④Please right click the windows —setting -troubleshooting —other troubleshooters— bluetooth—run , let the PC diagnose the problem and solve it automatically.
    ⑤.Please go to the windows terminal (admin) > type in : sfc /scannow > then wait until finished.
    ⑥.Please try this software https://mega.nz/file/X7hGVZwb#1tA5wEJhxH8BDtKxeB5qS2ZiIEUByAVZoOnzhSf4-Pg or https://url.bee-link.cn/meE5
    It didn’t work, I have ask for the refund.
      8 days later
