Sergi Is there a way to disable auto-power on when restarting the power? I turn off in the BIOS, auto-power on, wake-up on LAN and also on network devices, but my U59 still boots up Thanks in advance
Beelink CS-George Hi there, please send us a picture of SN on the bottom of the PC, we will check if you need to downgrade the BIOS
Beelink CS-George Hi there, please flash this BIOS https://url.bee-link.cn/CU7Q, here is the tutorial https://url.bee-link.cn/lbNf
Beelink CS-George Sergi Sorry, but the picture is not clear, could you please send another one or a link ?
Sergi Hi George, This is the image of the error: 18 - Error: Secure flash rom verify fail [https://we.tl/t-OfUhKslh9s] (https://) Thanks in advance
Beelink CS-George Sergi Hi there, Did you enable secure boot in the BIOS ? Please repeatedly press delete key as soon as you turn on the PC, go to BIOS. On Save&Exit page, please click Restore defaults, press enter to confirm, then press F4 to save.
Sergi Hi George, I do it but I have the same error before. 18 - Error : Secure Flash Rom Verify fail Thanks for help me
