Sergi Hi George, So, does that mean I can’t go back to the other BIOS to disable boot on startup? There is no way to disable start-up when power on? Thanks
Beelink CS-Yvette Sergi Thank you for your reply. Yes. That’s the current situation. It might be feasible to manually flash the BIOS by sending the machine back to China.
