desperado_gmbh
Hi there
Sorry for the situation and any inconvenience.
Please don`t worry.
Please try some solutions here :
For BT ,
1.CLR CMOS
Secondly, Please hit the “CLR CMOS” button/hole for about 10 seconds.
For some models the CMOS hole could be in the Audio port .
Please wait until 10 minutes later (THIS IS VERY IMPORTANT),
Then plug the power supply and HDMI cable back in, turn on the PC again,
2.Please right click the windows–computer management–double click Services–bluetooth–start the service.
3.Please right click the windows —setting -troubleshooting —other troubleshooters— bluetooth—run , let the PC diagnose the problem and solve it automatically.
4.Please go to the windows terminal (admin) > type in : sfc /scannow > then wait until finished.
5.Please try this software https://mega.nz/file/X7hGVZwb#1tA5wEJhxH8BDtKxeB5qS2ZiIEUByAVZoOnzhSf4-Pg
For pin code .
Please try this way :
- Please disconnect the network at first, while you turn on the PC
- Then press ALT+Tab
- Press Esc several times.
For the fan :
Please try Softwares : HWMonitor、SpeedFan to optimize the fan .
