Beelink CS-Ian Chan
I’m sorry but I missed a step, it was a few weeks ago when I originally found the workaround and hadn’t looked at it again since, however I just tested again today.
You must do a hard power cycle after running the system hot, just shutdown, pull the plug for a few seconds. It didn’t work for me on otherwise
Note: I ran the system for 5 minutes after the temp reached 70C, and it fluctuated between 70-73C.
I unplugged the system for a couple of seconds after step 4, but at any point after getting the system toasty should be fine, as I indicated in my previous testing it took quite a while after the machine had been running hot for the NICs to become unstable again from a hard power cycle.
Sorry again for the missed step, I should have tested again before posting.
Anyway that got me back from this to stable, surely it must work for some of you😯
[ 111.690001] ixgbe 0000:c5:00.1 enp197s0f1: NIC Link is Down
[ 111.697009] ixgbe 0000:c5:00.0 enp197s0f0: NIC Link is Down
[ 111.969961] ixgbe 0000:c5:00.0 enp197s0f0: NIC Link is Up 10 Gbps, Flow Control: None
[ 111.983951] ixgbe 0000:c5:00.1 enp197s0f1: NIC Link is Up 10 Gbps, Flow Control: None
[ 128.256092] ixgbe 0000:c5:00.1 enp197s0f1: NIC Link is Down
[ 128.263099] ixgbe 0000:c5:00.0 enp197s0f0: NIC Link is Down
[ 128.467045] ixgbe 0000:c5:00.0 enp197s0f0: NIC Link is Up 10 Gbps, Flow Control: None
[ 128.481059] ixgbe 0000:c5:00.1 enp197s0f1: NIC Link is Up 10 Gbps, Flow Control: None
[ 129.067995] ixgbe 0000:c5:00.1 enp197s0f1: NIC Link is Down
[ 129.075080] ixgbe 0000:c5:00.0 enp197s0f0: NIC Link is Down
[ 129.266048] ixgbe 0000:c5:00.0 enp197s0f0: NIC Link is Up 10 Gbps, Flow Control: None
[ 129.282036] ixgbe 0000:c5:00.1 enp197s0f1: NIC Link is Up 10 Gbps, Flow Control: None
[ 131.295017] ixgbe 0000:c5:00.0 enp197s0f0: NIC Link is Down
[ 131.302016] ixgbe 0000:c5:00.1 enp197s0f1: NIC Link is Down
[ 131.566971] ixgbe 0000:c5:00.0 enp197s0f0: NIC Link is Up 10 Gbps, Flow Control: None
[ 131.580977] ixgbe 0000:c5:00.1 enp197s0f1: NIC Link is Up 10 Gbps, Flow Control: None
[ 231.094861] furmark-gui calls setitimer() with new_value NULL pointer. Misfeature support will be removed
[ 247.021543] ixgbe 0000:c5:00.1 enp197s0f1: NIC Link is Down
[ 247.028531] ixgbe 0000:c5:00.0 enp197s0f0: NIC Link is Down
[ 247.257469] ixgbe 0000:c5:00.0 enp197s0f0: NIC Link is Up 10 Gbps, Flow Control: None
[ 247.272462] ixgbe 0000:c5:00.1 enp197s0f1: NIC Link is Up 10 Gbps, Flow Control: None
[ 247.587501] ixgbe 0000:c5:00.0 enp197s0f0: NIC Link is Down
[ 247.594498] ixgbe 0000:c5:00.1 enp197s0f1: NIC Link is Down
[ 247.857449] ixgbe 0000:c5:00.0 enp197s0f0: NIC Link is Up 10 Gbps, Flow Control: None
[ 247.871453] ixgbe 0000:c5:00.1 enp197s0f1: NIC Link is Up 10 Gbps, Flow Control: None
[ 250.160925] ixgbe 0000:c5:00.0: Adapter removed
[ 250.160934] ixgbe 0000:c5:00.0: Warning firmware error detected FWSM: 0xFFFFFFFF
[ 250.160936] ixgbe 0000:c5:00.0: Firmware recovery mode detected. Limiting functionality. Refer to the Intel(R) Ethernet Adapters and Devices User Guide for details on firmware recovery mode.
[ 250.161454] ixgbe 0000:c5:00.0: removed PHC on enp197s0f0
[ 253.956182] ixgbe 0000:c5:00.1 enp197s0f1: NETDEV WATCHDOG: CPU: 27: transmit queue 28 timed out 5890 ms
[ 253.956210] ixgbe 0000:c5:00.1 enp197s0f1: initiating reset due to tx timeout
[ 260.096991] ixgbe 0000:c5:00.1 enp197s0f1: NETDEV WATCHDOG: CPU: 27: transmit queue 28 timed out 12032 ms
[ 260.097005] ixgbe 0000:c5:00.1 enp197s0f1: initiating reset due to tx timeout
[ 265.728823] ixgbe 0000:c5:00.1 enp197s0f1: NETDEV WATCHDOG: CPU: 27: transmit queue 28 timed out 17664 ms
[ 265.728835] ixgbe 0000:c5:00.1 enp197s0f1: initiating reset due to tx timeout
[ 266.788260] ixgbe 0000:c5:00.1: Adapter removed
[ 266.788266] ixgbe 0000:c5:00.1: Warning firmware error detected FWSM: 0xFFFFFFFF
[ 266.788268] ixgbe 0000:c5:00.1: Firmware recovery mode detected. Limiting functionality. Refer to the Intel(R) Ethernet Adapters and Devices User Guide for details on firmware recovery mode.
[ 266.788662] ixgbe 0000:c5:00.1: removed PHC on enp197s0f1
