Pereira98 That’s not what I meant and said.
I only said that EU plug, normally stands for the two-pole, far more compatible Europlugs and not for DE (Schuko) Type F. Also as soon as a manufacturer requires grounded plugs for their device, there are no longer any EU plugs, then you have to look individually, because as I said, even within the EU then Italy(Type L), France(Type C/E), Malta(Type G), Denmark(Type K), Ireland(Type G) have other plugs than DE (Schuko)-Type F.
In addition, the issue is now settled for me, I replaced the plug and that’s it. However, the criticism remains and would have occurred even if it had been a Swiss online shop. We live in a globalized world, so I expect things like this to be taken into account, especially since it’s handled flawlessly even on AliExpress, where I wouldn’t really expect it.
So now we should get back to the actual topic, namely whether the Intel E610-XT2 NICs are working properly or not and whether the fix for them is coming or not. Because unfortunately, this problem cannot be solved as easily as replacing a plug.
I haven’t tested the Beelink 100% yet either. First I had to order new NVMEs because the built-in Crucial P310 (QLC E-Waste with only 440TBW) is of too poor quality for my taste. I have now ordered new ones: Lexar NM790 2TB (TLC 1500TBW) and 4TB (TLC 3000TBW) which will arrive tomorrow, together with a few other components that I need to use the Beelink comfortably.
