Hi,
The SER8 8745HS systems I purchased came with two 16GB RAM modules which equals 32 GB total. I want to replace the 16GB RAM modules with 64GB modules so that I can increase my RAM to 128GB total.
So, I’m asking for the RAM specifications for 64GB memory modules compatible with the SER8 8745HS.
I know that the modules have to be SO-DIMM DDR5, but what are the specific latency/timings and frequency that I should buy? For example, what are acceptable values for things like CAS Latency (tCL), RAS to CAS Delay (tRCD), Row Precharge (tRP), Row Active Time (tRAS), and what is the maximum RAM speed that the motherboard can handle (4,800, 5,200, 5,600)?
Thank you.
