samji
①Please take out the RAM ,please clean the contacts of the RAM with a rubber. Here is the tutorial:https://mega.nz/file/XqZX0TIR#_DtO2oa4aRP4bWtvxgKLj4QGhBpQ959cg5U3Yw4u1Cc
⑤Update graphics driver: Please uninstall the graphic driver in the device manager and install the new one. Here is the driver source :[https://url.bee-link.cn/OAQN].
