Socrates669
For automatic shutdown, you can try:
1Please change another power supply.
2.Overheating. If your PC is overheating, please check if the fan spins. You can also turn off the turbo boost. Go to control panel —power option—change to High performance— change plan setting—advanced setting —processor power management— change both 100% to 99% , click save.
3.Update graphics driver: Please uninstall the graphic driver in the device manager and install the new one. Here is the driver source: https://url.bee-link.cn/UX3B tutorial: https://url.bee-link.cn/wEmk
