Your intelligent autopilot for AMD Ryzen performance & efficiency! 🎯
Boost your productivity and save energy: RyzenZPilot automatically switches between optimized power profiles based on your active applications. Whether gaming 🎮, video editing 🎬, or office work 📊 – your Ryzen system always runs in the perfect mode!
SOFTWARE PURPOSE & FUNCTIONALITY:
The tool provides users with a graphical interface to safely adjust CPU power profiles, voltage curves, and thermal settings
through AMD’s official hardware interfaces. It’s built around the RyzenAdj library and serves a similar function to established tools like AMD’s own Ryzen Master, MSI Afterburner, UXTU, or CPU-Z, etc. - all of which require elevated system privileges for hardware access.
Because of this some antivirus engines may temporarily flag RyzenZPilot due to heuristic, which is known as a ‘false positive.’ Independent resources explain why this happens and how to report it for correction. You can verify our builds on VirusTotal and, if needed, contact the affected vendors using their official false‑positive channels. Currently only 2-3 vendors on Virus Total flagged it! We continue to file submissions and monitor reclassifications.
[ Freeware ] RyzenZPilot v3.1.3
The tool has 2 premade profiles for the Ryzen 8745hs (SER8) and the AMD Ryzen™ Al Max+ 395 (GTR9 Pro) but it’s highly customizable.
System Requirements
💻 CPU: AMD Ryzen processor (all generations)
🪟 OS: Windows 10/11 (64-bit)
💾 RAM: Minimum 50MB (runs extremely resource-efficiently)
💽 Storage: 15MB disk space
⚡ Permissions: Administrator privileges for power management
