Mitchell
Don’t worry, the PC has one-year warranty. Please send us a picture of SN on the bottom of the PC and a picture of the purchase record. Here are some potential solutions: First,please unplug the power supply and HDMI cable. Please press the pinhole of “CLR CMOS” with a pin for about 10 seconds.Ten minutes later, plug the power supply and HDMI cable, turn on the PC again. Please wait about one or two minute, if you can go to the system, Please repeatedly press delete key as soon as your restart the PC, go to BIOS. Go to Boot option, enable fast boot, press F4 to save. Here is the tutorial [ https://mega.nz/file/2nIRGaYI#M2aIM2bkOJshrhE8sK8MNiKopfyHlqyjnn86TypZp2w]. If the problem persists, please try other solutions:
1.Please change another HDMI cable or power supply.
2.Please take out the RAM ,please clean the contacts of the RAM with a rubber. Here is the tutorial https://mega.nz/file/XqZX0TIR#_DtO2oa4aRP4bWtvxgKLj4QGhBpQ959cg5U3Yw4u1Cc
3.Please tell us if the Keyboard light is on ?(Very important). If the keyboard light is on, it should go to the system, we need to troubleshoot HDMI or the monitor.
