Sophie_Moon Hello! I can’t activate my Windows 11 Pro. I have a: SN: Y58004JG00529 SER5 PRO-E-32500EJ0W64PRO-DP/XB Can you please help me? Thank you.
Beelink CS-Rose f1fan Thanks for your letter and sorry for the late reply. May I have a picture of the sn code at the bottom of the machine? Then I could send you the product key accordingly. Look forward to your reply.
RJB I’m having the same problem. This seems to be a common theme lately. SN: A58003BE00834 SER5-MAX-E-32500EJ0W64PRO-DP/XA
