mario_70 Hi, WoL stopped working after i upgrade BIOS to version 0.35. Hope you’ve got solution. Regards
Beelink CS-Rose Our current machines have WOL enabled by default, and do not need to be set in the BIOS. WOL does not have this option in the BIOS and has been hidden. Please refer to set up WOL’s tutorial: https://mega.nz/file/DipT3RoZ#mPFV8aByadxGMd-t21xDgK4Ak7vA5WYFAbWHph0KwIA
mario_70 I did this setup and was working pretty well on Bios 0.29, but stopped working after i upgrade Bios to 0.35, thats why im asking where is the problem?
Beelink CS-Ian Chan mario_70 Hi there Did you try and reset the WOL function ? See how it works. And try cmos and scanning CLR CMOS First, please unplug the power supply and HDMI cable. Secondly, Please hit the “CLR CMOS” button/hole for about 10 seconds. For some models the CMOS hole could be in the Audio port . Please wait until 10 minutes later (THIS IS VERY IMPORTANT), Then plug the power supply and HDMI cable back in, turn on the PC again, once turn on the PC, you will need more than one minute to wait for the PC to enter the system. See if it works. Please try few more times. 2. Go to the windows terminal (admin) > type in : sfc /scannow > then wait until finished.
mario_70 Thank you for your answer. I’ll do fix the problem following your suggestion. Hope it will help.
Beelink CS-June mario_70 Hello there, You are welcome. We are happy to help you. If you have any updates, please feel free to contact us. Have a nice day!
