MC71
Could you please send us a picture of SN code at the bottom of machine ?
Please reset the system as follow:
1)Enter the safe mode, and reset the system.
Do this many times until Windows boots into the Recovery Environmen.
2)If Windows will boot into the Recovery Environment and from there you can access System Repair, Safe Mode, Command Prompt . . . etc.
3)If the above fails, go to Troubleshoot - Advanced Options - Reset this PC
Then start the Reset
Have a nice day!
