tuttiejj
Please send us a picture of SN on the bottom of the PC.
② Please take out the RAM ,please clean the contacts of the RAM with a rubber. Here is the tutorial https://mega.nz/file/XqZX0TIR#_DtO2oa4aRP4bWtvxgKLj4QGhBpQ959cg5U3Yw4u1Cc
③ Please check if the fan spins?
④ Please tell us if the Keyboard light is on ?(Very important). If the keyboard light is on, it should go to the system, we need to troubleshoot HDMI or the monitor.
