I’m using Ubuntu 24.04.3 LTS. I can see the device
❯ boltctl list
● AZW Mate SE
├─ type: peripheral
├─ name: Mate SE
├─ vendor: AZW
├─ uuid: e4ec8780-0070-eb70-ffff-ffffffffffff
├─ generation: USB4
├─ status: authorized
│ ├─ domain: 09883804-908d-d890-ffff-ffffffffffff
│ ├─ rx speed: 40 Gb/s = 2 lanes * 20 Gb/s
│ ├─ tx speed: 40 Gb/s = 2 lanes * 20 Gb/s
│ └─ authflags: none
├─ authorized: Wed 12 Nov 2025 12:36:54 AM UTC
├─ connected: Wed 12 Nov 2025 12:36:52 AM UTC
└─ stored: Mon 10 Nov 2025 10:59:30 PM UTC
├─ policy: iommu
└─ key: no
However I’m seeing problems in the logs on bootup.
Nov 12 11:36:52 brett kernel: ACPI: Added _OSI(Module Device)
Nov 12 11:36:52 brett kernel: ACPI: Added _OSI(Processor Device)
Nov 12 11:36:52 brett kernel: ACPI: Added _OSI(Processor Aggregator Device)
Nov 12 11:36:52 brett kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SBRG.EC0], AE_NOT_FOUND (20240827/dswload2-162)
Nov 12 11:36:52 brett kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20240827/psobject-220)
Nov 12 11:36:52 brett kernel: ACPI: Skipping parse of AML opcode: Scope (0x0010)
Nov 12 11:36:52 brett kernel: ACPI: 31 ACPI AML tables successfully acquired and loaded
Nov 12 11:36:52 brett kernel: ACPI: USB4 _OSC: OS supports USB3+ DisplayPort+ PCIe+ XDomain+
Nov 12 11:36:52 brett kernel: ACPI: USB4 _OSC: OS controls USB3+ DisplayPort+ PCIe+ XDomain+
Nov 12 11:36:52 brett kernel: ACPI: Interpreter enabled
Nov 12 11:36:52 brett kernel: ACPI: PM: (supports S0 S3 S4 S5)
Nov 12 11:36:52 brett kernel: ACPI: Using IOAPIC for interrupt routing
Nov 12 11:36:52 brett kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
Nov 12 11:36:52 brett kernel: PCI: Ignoring E820 reservations for host bridge windows
And also -
Nov 12 11:36:52 brett kernel: ACPI: bus type thunderbolt registered
Nov 12 11:36:52 brett kernel: r8169 0000:c2:00.0 enp194s0: renamed from eth0
Nov 12 11:36:52 brett kernel: pcieport 0000:00:01.1: pciehp: Slot(0): Link Down
Nov 12 11:36:52 brett kernel: pcieport 0000:00:01.1: pciehp: Slot(0): Card not present
Nov 12 11:36:52 brett kernel: pcieport 0000:02:05.0: Unable to change power state from D3hot to D0, device inaccessible
Nov 12 11:36:52 brett kernel: pcieport 0000:02:05.0: Runtime PM usage count underflow!
Nov 12 11:36:52 brett kernel: pcieport 0000:02:04.0: Unable to change power state from D3hot to D0, device inaccessible
Nov 12 11:36:52 brett kernel: pcieport 0000:02:04.0: Runtime PM usage count underflow!
Nov 12 11:36:52 brett kernel: pcieport 0000:02:03.0: Unable to change power state from D3hot to D0, device inaccessible
Nov 12 11:36:52 brett kernel: pcieport 0000:02:03.0: Runtime PM usage count underflow!
Nov 12 11:36:52 brett kernel: xhci_hcd 0000:05:00.0: remove, state 1
Nov 12 11:36:52 brett kernel: usb usb2: USB disconnect, device number 1
Nov 12 11:36:52 brett kernel: xhci_hcd 0000:05:00.0: xHCI host controller not responding, assume dead
Nov 12 11:36:52 brett kernel: nvme nvme1: allocated 64 MiB host memory buffer (1 segment).
Nov 12 11:36:52 brett kernel: nvme nvme0: allocated 64 MiB host memory buffer (1 segment).
Nov 12 11:36:52 brett kernel: usb usb1-port1: couldn't allocate usb_device
Nov 12 11:36:52 brett kernel: xhci_hcd 0000:05:00.0: USB bus 2 deregistered
Nov 12 11:36:52 brett kernel: usb usb1: USB disconnect, device number 1
Nov 12 11:36:52 brett kernel: xhci_hcd 0000:05:00.0: Host halt failed, -19
Nov 12 11:36:52 brett kernel: xhci_hcd 0000:05:00.0: Host not accessible, reset failed.
Nov 12 11:36:52 brett kernel: xhci_hcd 0000:05:00.0: USB bus 1 deregistered
Nov 12 11:36:52 brett kernel: pcieport 0000:02:01.0: Unable to change power state from D3hot to D0, device inaccessible
Nov 12 11:36:52 brett kernel: pcieport 0000:02:00.0: Unable to change power state from D3hot to D0, device inaccessible
Nov 12 11:36:52 brett kernel: pci_bus 0000:03: busn_res: [bus 03] is released
Nov 12 11:36:52 brett kernel: pci_bus 0000:04: busn_res: [bus 04] is released
Nov 12 11:36:52 brett kernel: pci_bus 0000:05: busn_res: [bus 05] is released
Nov 12 11:36:52 brett kernel: pci_bus 0000:06: busn_res: [bus 06] is released
Nov 12 11:36:52 brett kernel: pci_bus 0000:07: busn_res: [bus 07] is released
This would seem to be a BIOS problem? I can provide more logging if neccessary.
