allenl Hi, I can’t seem to find the bios download link for SER5 Pro 5700. Is it the same as ser5 pro 5800? Here is the serial number:
Beelink CS-Rose allenl This depends on your current bios version. Please press delete key as soon as you turn on the PC, so that you can go to BIOS. Please send us a picture of the Main page. We will check if you need to update the BIOS.
