Hi
I cannot get my eGPU working on my SER9 Pro. When it is plugged into the USB4 port, nothing happens - I can’t get the machine to recognise and accept the card - I can’t see it in the BIOS or in the OS. I have tested it on another PC keeping everything the same, and it works.
Mini PC: Beelink SER9 Pro AMD Ryzen™ AI 9 HX 370
eGPU Dock: AOOSTAR AG02
Card: ASUS PRIME NVIDIA GeForce RTX 5070 Ti 16GB
BIOS Version: SER9T204
The problem seems to be completely caused by the SER9 Pro. Please can you advise if there is a BIOS setting I need to change, or if a BIOS update is needed, or something else?
The label on the back of the machine has the following details.
8B.024120834NA0
SN:DHX375GG70271
SER9Pro-L-321TBVK0W64PRO-DP/XA
Thanks
