Ash1608
1.Test the GPU without the dock: To confirm the dock is the problem, you would need to connect the Arc B570 GPU directly to your system. Since you mentioned this isnât possible with the mini PC, it makes troubleshooting difficult.
2.Consider the âm.2 to oculink adapterâ: This adapter is a crucial but unofficial link in your setup. Its quality or specific model can directly block advanced features like Resizable BAR, and it may not have been designed with this in mind.
3.Contact Aoostar Support: Reach out to the manufacturer of your AG02 dock. Ask them specifically if their dock, when used with an m.2 to oculink adapter, supports Resizable BAR (or âPCIe Above 4G Decodingâ) passthrough. If they say it doesnât, you have your answer.
4.Try connecting your monitor to the SER7âs USB4 port instead of the oculink dock, if possible. If it works there but not via oculink, the dock/adapter is likely the issue.
