Subject: Pre-purchase question: GTi13 Ultra + EX Dock reliability with RTX 3090, 24/7 use
I’m considering purchasing a Beelink GTi13 Ultra (32GB) along with the EX Dock (600W) to run an NVIDIA RTX 3090 (24GB, 350W) for a home AI server that will run continuously (24/7), handling sustained multi-core CPU workloads alongside GPU inference.
Before I order, I have a few questions I’d appreciate your help with:
As mentioned above by other “after a full system shutdown and cold restart, the external GPU shows no video output until the system is first booted on the internal display and then switched over”, has this been resolved in current firmware/BIOS? If not, is there a recommended workaround or an expected fix timeline?
I also saw a separate report (regarding the GTi14 Ultra + EX Dock) describing CPU multicore performance dropping significantly (roughly halved in Cinebench R23) when a discrete GPU is connected to the dock, apparently due to thermal/power throttling. Does the GTi13 Ultra experience anything similar when the EX Dock is connected and under sustained heavy CPU load together with GPU use? I want to confirm the CPU is not throttled by having the dock connected.
Can you confirm the EX Dock’s 600W power supply is sufficient to run an RTX 3090 (350W TDP) reliably, including transient power spikes, without needing a separate power source?
What warranty coverage applies to a new GTi13 Ultra unit and the EX Dock separately, and does that warranty cover issues related to eGPU dock use specifically?
Thank you for your help — I look forward to your response.
Best regards,
CY
