Hi all,
There is new firmware and drivers out that you could try (20-March-2026).
I do also have the issue with the E610-XT nic on my GTI15 (with T205 bios).
My main gripe has been video stutters/mouse lockups and buzzing through the speakers when using the internal audio (this all happens simultaneously). I used an app called latencymon and can see these stalls caused by the ndis network driver causing very high DPC latency (windows machine).
That latency issue is better with the later drivers, but to completely allevaite it i had to stop using auto negotiate on the NIC port and fix my port speed to 1Gbs full duplex in device manager (even though my network is actually 2.5Gb).
But thought I would let you guys know that there is now a later NVM firmware for the NICS along with newer drivers for the operating system.
Beelink were/are suggesting i need to send the unit back from the UK to China for them to “test”. I have offered to work with them to islolate the exact issue as I am not keen on the idea of an expensive piece of kit going missing in transit, or being without the PC for how ever many weeks that will be though for what I think is driver or configuration issues with the NIC chipset, But that is what support are sticking with, so not happy about that stance.
https://www.intel.com/content/www/us/en/download/845405/non-volatile-memory-nvm-update-package-for-intel-ethernet-e610-series-windows.html
