Thank you very much for the excellent instructions and files. It took us nearly two days to download the main file from Mega, but we finally did it, and the instructions worked well. The weird thing is that Windows-10 gets installed, so I’m assuming it will then prompt us to upgrade to Windows-11. I will update on the progress as we go through this - thanks again!
Quick question: We just got a call that another customer’s machine had exactly the same problem (failed SSD). If we replace the SSD with a new one, can we use the same instructions/files from above or we need to send you the serial #'s again? Thank you..
