Beelink CS-George it doesn’t work either. I have a SER5 MAX, too, and that works fine there. I think this is a small bug in SER8 v029 BIOS. Full On Mode works (fan goes maximum), but when you set to PWM Manually or Automatic modes, it does the same. No matter what mode or values I set, it will always go with default settings. This is why I asked you to speak with the firmware guys, because they will know what I am talking about. This is easy to solve as it just seems to be a bug.
Same applies to Advanced > OEM Features Management > Usb Power Controller. No matter what I set, it will always be “All ON”. I think this is also a small bug, and these values are ignored.
This is a good PC, but these small bugs are annoying, and very easy to be solved by Beelink.
