The USB4 connector still does not work properly, anything plugged into this socket works at USB2 speed. When I connect the monitor through this connector with a USB4 cable, the monitor does not display the image, the same cable connected to the Mac Mini M4 displays a 4k 120Hz image. The external drive in the Ugreen CM850 housing works as if it were connected to the USB2 port, while when connected to a Mac Mini it works at full speed of approx. 3 Gbps writing and reading, KC3000 2TB drive. I guess you can afford to buy the components to test the USB4 socket. Please let me know what I should do to connect the computer to the monitor with a USB C cable. I have a Gigabyte M32U 4k monitor.
