No, not really. Running the default Beelink installed windows (and a default BIOS setting).
This is when I run powercfg -a
C:\>powercfg -a
The following sleep states are available on this system:
Standby (S0 Low Power Idle) Network Connected
Fast Startup
The following sleep states are not available on this system:
Standby (S1)
The system firmware does not support this standby state.
This standby state is disabled when S0 low power idle is supported.
Standby (S2)
Standby (S3)
The current Device Guard configuration has disabled this standby state.
Hibernate
The hiberfile type does not support hibernation.
Hybrid Sleep
Standby (S3) is not available.
Hibernation is not available.
The hypervisor does not support this standby state.
Is there any other way to check (via commandline) if fastboot is working or something/process is preventing it to do so?
