I try to reinstall Win11 Pro on my Ser5. But I’v got message than it not support Win 11 Pro. Security Device Support is Enabled in BIOS, but it write’s that No Security Device Found. Self test for NVME passes Ok. I can see and copy files from it. And I don’t know windows SN to reinstall.
Image description
    Mark_l
    We have replied to you via private message, please check it.
    Best regards!
    Wendy
    Customer Support
      support6
      And what about “No Security Device Found.” message? I need BIOS upgraid? Can you provide me correct link for BIOS for my model?
        Mark_l
        Please send a complete screenshot of your current BIOS version page.
        Here is a link on how to check the BIOS version:https://url.bee-link.cn/EqEu
        After you provide the current BIOS version, we can determine which one your BIOS is suitable for?
        Best Regards!
        Wendy
        Customer Support
        Mark_l
        Best Regards!
        Wendy
        Customer Support
        Mark_l
        Best Regards!
        Wendy
        Customer Support
          Mark_l
          Your BIOS is the lastest, you don`t need to update it.
          If you have any questions during the use of the machine, please feel free to contact us.
          Have a nice day!
            Mark_l
            We have sent you the latest BIOS version via private message and addressed the issue you mentioned with the Windows system. Please check your inbox carefully.
            Best regards!
            Wendy
            Customer Support
