Hi all,
I’ve been tinkering with adding the OCuLink interface shown below to the SER9 mini pc via the second M.2 slot.
Now I can connect an old external eGPU to the SER9 via a Minisforum DEG1 OCuLink dock:
I can use the external eGPU in games, etc. However, as you can see in the report from GPU-Z, even though the eGPU reports that i can run x16 @3.0, it seems that the eGPU only physically uses 1x PCIe lane!? Can these old eGPUs not run via OCuLink with more than 1x @3.0 !?!?? Has anyone experience with these cards?? Sorry for the bad picture quality:
If any of you want to tinker with OCuLink on SER9, here is the STEP file for the insert needed for the assembly of the M.2 to OCuLink adapter: Tingiverse STEP File
