I using a ser8 8745hs.
testing on default bios, no lan cable, only wireless setting.
When It enter sleep mode, It automatically wake from sleep mode when 1-40 minutes later. (ramdomly)
And In sleep mode, system fan spins and stops repeatedly.
In system event log, It said waked up by powerbutton. but even if all usb device plugged off this error happend
If I set Wol off on bios, fan keeps spinning on sleep mode.
And If I remove ax200 wireless lan card, default bios setting sleep mode works perfect. No wake up from sleep mode.
What sould I do for solving this problem.
I try reset my windows, but nothing changed.
