I am having similar problems across three of these devices (MINISV1-A-8256SD0W64PRO-B). I bought 12V 5A PSUs to see if that would remedy the problem of running for a bit and then blackscreening, crashing, clearing CMOS, waiting 10, and rebooting. I’ve tried the latest BIOS from 11/24 and that has not helped. New CMOS batteries in each machine. CMOS seems to not always save or saves and then looses settings sometimes (no CMOS clearing). Also, unplugging and holding the red power button for 30 s, seems to allow for a reboot occasionally with the system powering up with fan at 100% and then quieting down before posting. RAM reseated and cleaned. Known working RAM used. Different SSD SATA drives tried. When trying to change the fan settings, thermal settings within BIOS, it seems like those are ignored and that fan cooling is on its own trajectory. Limiting power for the CPU to 10w also seems to be ignored. When connected to a watt meter, I am seeing a maximum of 20w. Underneath the 3A rating of the standard PSU. If I stress test the CPU, I may see some throttling (not sure and not what I have set in BIOS) and temps show for the cores at around 78 oC. I have changed out the thermal paste and reseated the heatsink. That provided no real change though the heat sink compound on all three seemed to be stiff and dried out. I can stress test (SilverBench web - Extreme) for a while and then it will eventually blackscreen and not reboot immediately. There is no indication that the CPU is getting too hot but the fan never really goes to 100% even set to do so in BIOS. So…. BIOS programming issue? (I’ve also reflashed the most current numerous times - scary because one does not know if the PC will suddenly shut off during the flash and brick it.) Have you see issues with PMIC in these? I find it interesting that I have three separate PCs with the same problem; however, it might just be all of them may have some sort of hardware failure? Still think this may be BIOS or at least the easier step for support to try. Thoughts , Customer Support at Beelink? Thanks.
