zefirz_ Model: SER8 8745HS I just received my unit and did a fresh Win11 install using Media Creation Tool, can you help me the following: drivers for the missing stuff under Device Manager is my BIOS latest version? any mirror link (e.g. MEGA) for the SWS.rar under uploads > SER > SER8-8745 > FW
Beelink CS-George Allizares The DP port is 1.4 Version, please buy an active DP1.4 to HMDI2.1 cable ,here is the reference : https://a.co/d/dQPFCna
Beelink CS-George groyer1969 Hello there, Please press delete key as soon as you turn on the PC, so that you can go to BIOS. Please send us a picture of the Main page. We will check if you need to update the BIOS.
zefirz_ Beelink CS-George Hi George, I have updated the AMD drivers but there are still missing devices under Device Manager. BTW will Beelink provide an up-to-date AMD driver? The version you shared was released in Aug 2024.
Beelink CS-George Allizares Hello there, Please press delete key as soon as you turn on the PC, so that you can go to BIOS. Please send us a picture of the Main page. We will check if you need to update the BIOS.
Beelink CS-George zefirz_ Please check the BIOS file in your private message. Here is the image https://url.bee-link.cn/WhWb Here is the picture tutorial https://mega.nz/file/KjZHyIqB#0EEVnG_1fWYCq_qL7GUYFGuD7nKqlV8FZWu78SVGXS4 Here is the Video tutorial https://mega.nz/file/rjw3DLjB#oCO056vM5R3bB2f1n9Kqj9aTF7eHDqGsmVghNekhsP4
desperado_gmbh zefirz_ Install the chipset driver. https://www.amd.com/en/support/downloads/drivers.html/chipsets/laptop-chipsets/amd-ryzen-and-athlon-mobile-chipset.html
zefirz_ desperado_gmbh thanks you Sir! now I’m left with these 2 after installing the chipset driver.
MonRyse Beelink CS-George Hi, i looked for your links but server seems to be overloaded, downloads cant start. Moreover also the page with tutorial is not loading (it show a login with an infinite spinner.) Can you help me?
Beelink CS-George MonRyse Hi there, Please send us a picture of SN on the bottom of the PC, we will send you the correct driver
mike_j68 Hi, I have an SER8 8845HS running Linux. SN: Y88454HF10507 SER8-L-321TBVK0W64PRO-DP/XA Current BIOS ver: SER8P5C8V23 Could you send me a bios update link. Thank you.
issab Hi, I have SER9 255 (non-Pro version) Serial number starting with B255. Could you please send me link to Factory OEM Windows image with all drivers included? Thank you.
Beelink CS-George issab Here is the image https://url.bee-link.cn/h7sd Here is the picture tutorial https://mega.nz/file/KjZHyIqB#0EEVnG_1fWYCq_qL7GUYFGuD7nKqlV8FZWu78SVGXS4 Here is the Video tutorial https://mega.nz/file/rjw3DLjB#oCO056vM5R3bB2f1n9Kqj9aTF7eHDqGsmVghNekhsP4 Here is the driver https://url.bee-link.cn/JDaT
Beelink CS-George zefirz_ Hi there, since they are not yellow exclamation , you don’t need to update them.
Beelink CS-George MonRyse Hi there , here is the driver https://mega.nz/file/DqJkDSwB#tywnbYKmXJwPzwOlkKdid4Mj9CYUZrDZt7AdfzTWY_E
