if you received my message reply here what to do
Андрей andryva@gmail.com
Приложения
9 апр. 2025 г., 10:12
кому: support-pc
Hello. I reset the BIOS to the initial settings as written in the instructions. I checked it really reset - all small changes were updated to default.
I made a screenshot of the BIOS and information from the BIOS in Windows - attached.
then I launched the AIDA 64 stress test. The computer turned off in the fourth minute of the test.
I filmed the test - a link to the file sharing service is attached
https://disk.yandex.ru/i/y-lo4zYsJuZeyQ
A screenshot of the results after switching on is attached
A photo of the PC serial number is attached.
Resetting the BIOS did not help.
What to do next?
Приложения
11 апр. 2025 г., 13:28 (12 дней назад)
кому: support-pc
Hello.
In addition to the previous answer.
I made a copy of the OS and booted from another disk (nvme) from the second slot of the PC. Everything is the same - shutdown under load when a certain temperature is reached.
What should I do?
