under no circumstances use 2 connectors instead of 3
under no circumstances use the gpu under high load (3A games at maximum and high settings)
otherwise it will lead to melting of the power connectors
The power supply in the exdock is only rated for 300 watts and it is of terrible quality
it is better to buy a docking station that allows you to use your own power supply, for example from Minisforum
