thorpemark
1.Windows Power Settings:
Open Power Options > Change plan settings > Change advanced settings:
PCI Express > Link State Power Management > OFF
Hard disk > Turn off hard disk after > NEVER
USB settings > USB selective suspend > DISABLED
Processor power management > Minimum processor state > 5%
2.Device Manager Tweaks:
Under Disk drives, right-click each NVMe > Properties:
Uncheck “Allow the computer to turn off this device to save power” (Power Management tab)
Update drivers > Browse my computer > Let me pick > Select Standard NVM Express Controller
Samsung-Specific Fixes:
Install Samsung Magician to:
Check/update firmware (critical for 990 Pro stability)
Run Full Diagnostic Scan
Enable Over Provisioning (7-10% of drive capacity)
3.Validation Test
After applying all above:
Stop all monitoring scripts
Simulate idle:
powershell
powercfg.exe /requests /output C:\powerreport.txt
Check powerreport.txt for background processes preventing sleep
Let system idle 6+ hours, then attempt D: access
4.If Issue Persists
Hardware Isolation Test:
Swap the two NVMe drives (move OS to secondary slot)
Test with a different drive brand (some 990 Pros have L1.2 state bugs)
Use M.2 to USB enclosure ($15) to rule out slot issues
