Hi,
I have a Beelink EQ12 n100 and have attached a powered USB enclosure (Yottamaster USB 3.1 2 bay: https://support.yottamaster.com/shop?goods_id=97). I am running Ubuntu server 22.04.
When I attach the enclosure to any of the type A USB ports using a high speed cable (USB 3.1) I get I/O errors when accessing the disk. I have been able to transfer data at times but it will eventually disconnect part way through a transfer (rsync). When I use the type C port I am able to use the disks without issue (albeit at USB 2 speeds). When I attach the enclosure to the type A ports using a USB 2 cable I am also able to use the disk as expected.
I have attached the USB DAS to another computer and mounted, viewed and transferred files using the same cable without issue. Speeds we 200 MB/s.
I am running the BIOS version: N95V106
I have noted there are a few posts regarding similar issues. However, I could not identify any solution.
