Hello.
On August 25, 2024, I bought Beelink GTI14 185H. In November 2024, I replaced the RAM with 2×48=96gb.
The computer worked perfectly and without problems.
On September 6, 2025, I turn on the computer and there is no video signal. I found the problem as I had and followed all the steps.
https://bbs.bee-link.com/d/7110-gti14-no-hdmi-signal/2
These recommendations did not help, the computer booted after 5-10 attempts and after 1-2 minutes it froze. I tried to reinstall Windows, at the final stage of installation a blue screen with an error appeared. I did these operations several times with different iso Windows 10 and 11. The situation did not change, I could not completely install the system, the computer froze. I replaced NVMe, it did not help, the freeze did not go away. Returned the old memory 16×2=32gb, also did not help, the computer hung. According to temperature tests, everything was normal. There was no dust in the case and on the boards.
Then I read the forum bbs.bee-link.com and they advised me to flash the bios. I did everything according to the instructions, downloaded GTi14T108-Note-Only-original-version-is-T100-to-T105-can-update and launched it from a flash drive and at the update stage the computer froze at 9%, after 30-40 minutes I turned it off. After that I can’t enter the bios, the computer power turns on, the keyboard lights up, but there is a permanent black screen without a video signal.
I am attaching screenshots of the BIOS version before the firmware and a screenshot when the computer froze during the BIOS firmware process. What should I do? Why did such problems start a year after the warranty expired?
