Dear Beelink Support Team,
I would like to sincerely thank you for your prompt resolution of the audio issue I encountered with the SER8. The latest BIOS update has successfully addressed the problem, and my audio is now fully functional on Linux.
I truly appreciate the support and effort your team has put into resolving this matter. It’s clear that your dedication to ensuring compatibility and improving the user experience has made a significant impact.
Thank you again for your timely assistance and for fixing the issue that was preventing the BIOS from properly enabling audio on Linux.
Best regards
