- Edited
- #8
I tried all of the above. With different memory modules, and in two different Ser 8 mini PCs with different BIOS - everything goes wrong when using the CT32G56C46S5.M16B2 module (2025, Micron chips) - one or a pair does not matter. I think this is a hardware compatibility issue. similar behavior is also present on factory devices - exactly as I describe, you can read about it at the link [
These modules do not behave like this in other systems. Your team can check this issue themselves. Best regards
