support1 vitasonline Hi there, If your type c cable is not a all-in-one cable, then it cannot support video output, maybe it can only support video output,but not power supply. So when you connect another cable to charge it, it can output the video .
vitasonline support1 I use the same cables with T9 and GTi14 ! But in T9 it works power delivery + display port at the same time, and in GTi14 only power delivery works
support1 vitasonline Hi there, It might the cable incompatibility issue. When we use an all- in-one cable , it works with power delivery + display at the same time.
vitasonline I tried different cables and bought UGOURD Thunderbolt 4 Black 40G 240W 8K which has a PD chip and is defined in the E-marker cable as 0×315C vendor. But no cable displays an image.😂
support1 vitasonline That is weird. Could you please try another one , like https://amzn.asia/d/gOfPu20
narumivtl https://amzn.asia/d/5QDAgY3 I have bought this but is doesnt work to my usb c portable monitor and external gpu
vitasonline I updated thunderbolt chip firmware on my GTi14 155H with T105-BIOS firmware and finally now my monitor Arzopa Z1RC works through one type-c cable!!!
dahjah i would like to know exactly how to update thunderbolt firmware, as my thunderbolt port shuts off sometimes (after restart or shutdown) and seems like not much i can do to get it running again. I’ve tried a few different usb drives and none show up in the boot menu to boot from. I followed the tutorial on how to put the files on the usb drive and nothing is working for this port.
support1 dahjah Hello there, Please send us a picture of the SN on the bottom of the PC,we need to check your item model first
